Ir para o conteúdo principal
Bose-301 Series II Tweeter Replacement
O que você precisa
  1. Bose-301 Series II Tweeter Replacement, Tweeter: passo 1, imagem 1 %32 Bose-301 Series II Tweeter Replacement, Tweeter: passo 1, imagem 2 %32 Bose-301 Series II Tweeter Replacement, Tweeter: passo 1, imagem 3 %32
    • Begin the repair by placing the Bose-301 speaker vertically.
    • Using two hands, pull the speaker grill towards you and away from the speaker body.
  2. Bose-301 Series II Tweeter Replacement: passo 2, imagem 1 %32
    • Pull the main speaker grill towards you to remove it from the body structure.
  3. Bose-301 Series II Tweeter Replacement: passo 3, imagem 1 %32 Bose-301 Series II Tweeter Replacement: passo 3, imagem 2 %32 Bose-301 Series II Tweeter Replacement: passo 3, imagem 3 %32
    • Lay the speaker body on its back.
    • Using the Philips Screwdriver, carefully remove the four #2x19mm screws that mount the main speaker to the speaker body.
  4. Bose-301 Series II Tweeter Replacement: passo 4, imagem 1 %32 Bose-301 Series II Tweeter Replacement: passo 4, imagem 2 %32
    • Untwist the slack in the wires that are connected to the main speaker.
  5. Bose-301 Series II Tweeter Replacement: passo 5, imagem 1 %32 Bose-301 Series II Tweeter Replacement: passo 5, imagem 2 %32 Bose-301 Series II Tweeter Replacement: passo 5, imagem 3 %32
    • Carefully place the speaker off to the side.
    • Be sure to not place the speaker face down or put pressure on the speaker cone as this can damage the cone.
    • Be aware of the very strong magnet in the driver of the speaker, which can cause damage to electronic devices in close proximity.
    • Then untwist the slack in the wires that are connected to the tweeters.
  6. Bose-301 Series II Tweeter Replacement: passo 6, imagem 1 %32
    • Using the socket wrench and the 1/4" socket, unscrew the 12.5 mm bolt that mounts the tweeter to the bracket.
  7. Bose-301 Series II Tweeter Replacement: passo 7, imagem 1 %32
    • While holding the tweeter, use your other hand to feed the wire through the hole at the bottom of the tweeter mount.
  8. Bose-301 Series II Tweeter Replacement: passo 8, imagem 1 %32 Bose-301 Series II Tweeter Replacement: passo 8, imagem 2 %32
    • Remove the tweeter from the mount and locate the two wires that connect it to the speaker.
    • Using the pliers, untwist the wires that are attached to the two small rods at the bottom of the tweeter.
    • Repeat process for the second tweeter.
    • Be sure not to excessively bend the bare wires in order to reuse it for the replacement tweeters.
Conclusão
To reassemble your speaker, follow these instructions in reverse order.
3 outras pessoas executaram este guia.
Patrick Emery
Membro desde: 01/09/17
174 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 15-3, Remmell Spring 2017 Membro de USF Tampa, Team 15-3, Remmell Spring 2017
USFT-REMMELL-S17S15G3
Membros da 4
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 54
Duração total: 7,182
