Ir para o conteúdo principal
Bose Wave Radio AWR1-1W Speaker Replacement
O que você precisa
  1. Bose Wave Radio AWR1-1W Speaker Replacement, Base: passo 1, imagem 1 %32 Bose Wave Radio AWR1-1W Speaker Replacement, Base: passo 1, imagem 2 %32
    • Remove the four 19mm Phillips #2 screws from the base of the device.
  2. Bose Wave Radio AWR1-1W Speaker Replacement: passo 2, imagem 1 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 2, imagem 2 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 2, imagem 3 %32
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
  3. Bose Wave Radio AWR1-1W Speaker Replacement: passo 3, imagem 1 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 3, imagem 2 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 3, imagem 3 %32
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
  4. Bose Wave Radio AWR1-1W Speaker Replacement: passo 4, imagem 1 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 4, imagem 2 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 4, imagem 3 %32
    • Pinch and unplug the white connector from the device.
  5. Bose Wave Radio AWR1-1W Speaker Replacement: passo 5, imagem 1 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 5, imagem 2 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 5, imagem 3 %32
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
  6. Bose Wave Radio AWR1-1W Speaker Replacement: passo 6, imagem 1 %32
    • The base should now be completely detached from the device.
  7. Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: passo 7, imagem 1 %32 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: passo 7, imagem 2 %32 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: passo 7, imagem 3 %32
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  8. Bose Wave Radio AWR1-1W Speaker Replacement: passo 8, imagem 1 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 8, imagem 2 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 8, imagem 3 %32
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  9. Bose Wave Radio AWR1-1W Speaker Replacement: passo 9, imagem 1 %32
    • Lift the front grill away from the device.
  10. Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: passo 10, imagem 1 %32 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: passo 10, imagem 2 %32 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: passo 10, imagem 3 %32
    • Remove a total of eight 15mm Phillips #2 screws surrounding each speaker.
  11. Bose Wave Radio AWR1-1W Speaker Replacement: passo 11, imagem 1 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 11, imagem 2 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 11, imagem 3 %32
    • Gently pull each speaker out of the device.
  12. Bose Wave Radio AWR1-1W Speaker Replacement: passo 12, imagem 1 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 12, imagem 2 %32 Bose Wave Radio AWR1-1W Speaker Replacement: passo 12, imagem 3 %32
    • Pull the wire connected to the speakers out of the device.
    • You already disconnected this wire from the inside of the device earlier.
Conclusão
6 outras pessoas executaram este guia.
Cassie Harriman
Membro desde: 04/18/17
1.018 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team S15-G2, Banghart Spring 2017 Membro de Cal Poly, Team S15-G2, Banghart Spring 2017
CPSU-BANGHART-S17S15G2
4 Membros
6 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 101
Duração total: 5,944
