Ir para o conteúdo principal
Bose Wave Radio AWR1-1W Screen Replacement
O que você precisa
  1. Bose Wave Radio AWR1-1W Screen Replacement, Base: passo 1, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement, Base: passo 1, imagem 2 %32
    • Remove the four 19mm Phillips #2 screws from the base of the device.
  2. Bose Wave Radio AWR1-1W Screen Replacement: passo 2, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 2, imagem 2 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 2, imagem 3 %32
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
  3. Bose Wave Radio AWR1-1W Screen Replacement: passo 3, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 3, imagem 2 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 3, imagem 3 %32
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
  4. Bose Wave Radio AWR1-1W Screen Replacement: passo 4, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 4, imagem 2 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 4, imagem 3 %32
    • Pinch and unplug the white connector from the device.
  5. Bose Wave Radio AWR1-1W Screen Replacement: passo 5, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 5, imagem 2 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 5, imagem 3 %32
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
  6. Bose Wave Radio AWR1-1W Screen Replacement: passo 6, imagem 1 %32
    • The base should now be completely detached from the device.
  7. Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: passo 7, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: passo 7, imagem 2 %32 Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: passo 7, imagem 3 %32
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  8. Bose Wave Radio AWR1-1W Screen Replacement: passo 8, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 8, imagem 2 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 8, imagem 3 %32
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  9. Bose Wave Radio AWR1-1W Screen Replacement: passo 9, imagem 1 %32
    • Lift the front grill away from the device.
  10. Bose Wave Radio AWR1-1W Screen Replacement, Button Panel: passo 10, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement, Button Panel: passo 10, imagem 2 %32
    • Turn the device around.
    • Wedge the spudger into the larger part of the gap under the back of the device.
  11. Bose Wave Radio AWR1-1W Screen Replacement: passo 11, imagem 1 %32
    • Move the spudger up until the button panel is loose.
    • Push forward on the back of the button panel to disconnect the panel from the top of the device.
  12. Bose Wave Radio AWR1-1W Screen Replacement: passo 12, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 12, imagem 2 %32
    • Pull the button panel forward with one hand and push the screen assembly into the device with the other to disconnect the button panel.
    Awesome Guide! Came apart easily and quickly. Thx so much for your support with this. This definitely makes me want to learn more from your DiY fix it site. Harley18
    Tammy Gray - Responder
  13. Bose Wave Radio AWR1-1W Screen Replacement, Screen: passo 13, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement, Screen: passo 13, imagem 2 %32 Bose Wave Radio AWR1-1W Screen Replacement, Screen: passo 13, imagem 3 %32
    • Gently pull the top of the screen assembly away from the device.
  14. Bose Wave Radio AWR1-1W Screen Replacement: passo 14, imagem 1 %32 Bose Wave Radio AWR1-1W Screen Replacement: passo 14, imagem 2 %32
    • Lift the screen assembly upward and pull the white wire strip out of the device.
    Need to purchase white wire strip
    Bruce Ebneter - Responder
Conclusão
4 outras pessoas executaram este guia.
Cassie Harriman
Membro desde: 04/18/17
1.033 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S15-G2, Banghart Spring 2017 Membro de Cal Poly, Team S15-G2, Banghart Spring 2017
CPSU-BANGHART-S17S15G2
Membros da 4
Autoria de 6 guias
5 comentários
Great! This device is the best wave system in sound accurate. All frequencies sounds clear!!! Awesome!!!
srmrs - Responder
Nicely done.  Love the details.  Just one question - where can I get the replacement screen?
Patsy Hamilton - Responder
Instructions were PERFECT! Thank you. I found my replacement screen on ebay for $25, took a chance that it would work as stated by the seller. Otherwise I would have thrown the radio away.
John Stine - Responder
I performed the repair as directed. It was easy especially if you have a plastic spung to work with. Problem comes from the new display once installed shows all the characters? Unplugged it and re-plugged but still stuck in all character test mode?
plhamp - Responder
How to purchase White wire strip
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 32
Últimos 30 dias: 118
Duração total: 10,024
