Introdução
Screens often fail or stop displaying properly. Use this guide to remove and replace the screen assembly.
O que você precisa
Wedge the spudger between the top and front panel on the right side of the device.
Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
Repeat for the left side of the device.
Turn the device around.
Wedge the spudger into the larger part of the gap under the back of the device.
Pull the button panel forward with one hand and push the screen assembly into the device with the other to disconnect the button panel.
Awesome Guide! Came apart easily and quickly. Thx so much for your support with this. This definitely makes me want to learn more from your DiY fix it site. Harley18
Lift the screen assembly upward and pull the white wire strip out of the device.
4 outras pessoas executaram este guia.
5 comentários
Nicely done. Love the details. Just one question - where can I get the replacement screen?
Instructions were PERFECT! Thank you. I found my replacement screen on ebay for $25, took a chance that it would work as stated by the seller. Otherwise I would have thrown the radio away.
How to purchase White wire strip
