Ir para o conteúdo principal
Bose Wave Radio AWR1-1W Front Grill Replacement
O que você precisa
  1. Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: passo 1, imagem 1 %32 Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: passo 1, imagem 2 %32 Bose Wave Radio AWR1-1W Front Grill Replacement, Front Grill: passo 1, imagem 3 %32
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  2. Bose Wave Radio AWR1-1W Front Grill Replacement: passo 2, imagem 1 %32 Bose Wave Radio AWR1-1W Front Grill Replacement: passo 2, imagem 2 %32 Bose Wave Radio AWR1-1W Front Grill Replacement: passo 2, imagem 3 %32
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  3. Bose Wave Radio AWR1-1W Front Grill Replacement: passo 3, imagem 1 %32
    • Lift the front grill away from the device.
Conclusão
To reattach the front panel, press it into the front of the device until it pops back into place.
Uma outra pessoa concluiu este guia.
Cassie Harriman
Membro desde: 04/18/17
1.018 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team S15-G2, Banghart Spring 2017 Membro de Cal Poly, Team S15-G2, Banghart Spring 2017
CPSU-BANGHART-S17S15G2
4 Membros
6 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 31
Duração total: 1,564
