Introdução
Use this guide to replace the top motherboard on your device.
O que você precisa
Flip speaker over so that the bottom is facing up.
Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
Using the screwdriver, unscrew three screws.
Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
Using your hands, grip and separate the soft plastic and the metal casing away from each other with some small force.
My speaker seems to have a loose connection- I’m not sure if something just needs to be soldered— everything works- but the sound is not coming out- but if I put some pressure on it- I can get the sound to play. Any suggestions? Sad cause it’s bike season now!! Love this thing! Great job on the fixes guys!
10 outras pessoas executaram este guia.
12 comentários
Same here. My speaker had one circuit replacement on warranty but now need a second replacement and I not willing to pay half the price of a new speaker each a every year. Can you help please ?
My e-mail is fmtbmp@gmail.com
Hi, I need to buy the top and bottom circuit board and was wondering the same. Any help with where to purchase these would be appreciated,
Thanks, my email is fayclaybrook28@outlook.com
I am also looking for a top circuit board replacement. Where can I get one. michael@parsche.net
Hi, I need to find ribbon flex cable connecting the top to bottom circuit board. please email.me @ ronald.basmayor@gmail.com
Hello,
I need to buy the TOP CIRCUIT BOARD … Where Can I buy it or could you sell me one ? Thank you my mail is milos.debeljak@hotmail.com
How to find printouts of the circuit board in PDF format for repair, even as it is called, I can't find someone can help djoon.bro@gmail.com
Anyone know the J403 FPC connector part number? Looks like a 24pin part, maybe 0.5mm pitch? I think the Hirose part is similar but i’m not sure. Would be great to get a P/N.
I have been searching for the top circuit. Where can I buy it?
Where can I find the top board?? I'm from Nepal
