Ir para o conteúdo principal
Bose Soundlink Revolve AUX/USB Port Replacement
O que você precisa
  1. Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: passo 1, imagem 1 %32 Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: passo 1, imagem 2 %32
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve AUX/USB Port Replacement: passo 2, imagem 1 %32 Bose Soundlink Revolve AUX/USB Port Replacement: passo 2, imagem 2 %32 Bose Soundlink Revolve AUX/USB Port Replacement: passo 2, imagem 3 %32
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve AUX/USB Port Replacement: passo 3, imagem 1 %32 Bose Soundlink Revolve AUX/USB Port Replacement: passo 3, imagem 2 %32
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve AUX/USB Port Replacement: passo 4, imagem 1 %32 Bose Soundlink Revolve AUX/USB Port Replacement: passo 4, imagem 2 %32
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: passo 5, imagem 1 %32 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: passo 5, imagem 2 %32 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: passo 5, imagem 3 %32
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
Conclusão
14 outras pessoas executaram este guia.
Brian Butner
Membro desde: 09/27/17
861 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S6-G2, Remmell Fall 2017 Membro de USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
Membros da 4
Autoria de 4 guias
17 comentários
Any idea where I can find the USB/Aux board for sale?
Chad - Responder
Did you ever manage to find a place to buy it?
Steve Fantin -
You can buy a charging cradle for this device, maybe that helps..
adsf -
I am also looking for the usb port replacement part.
James Nowicki - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 69
Últimos 30 dias: 333
Duração total: 31,909
