Ir para o conteúdo principal
Bose Soundlink Mini II charging port Replacement
O que você precisa
    • flip the speaker over onto its back, then open the rubber covering the battery.
    • unscrew the battery using your screwdriver. carefully disconnect the battery from the motherboard.
    • be very careful not to damage the connector.
    • when replacing the battery, re apply the adhesive strip.
    • leave the battery aside.
    • carefully using a spludger, pry up the rubber holding the grills in place. then pry off the grill.
    • Be very careful with the grill as they bend easily.
    • using your spludger, carefully disconnect the ribbon cable connecting to the motherboard.
    • carefully remove the charging port assembly.
    • be VERY careful not to damage disconnecting the ribbon cable from the connector.
    • carefully pull out the charging port assembly.
    • be Extremely careful when attaching the new port to the assembly.
    • when replacing the port assembly, add the adhesive under the port.
Conclusão
Uma outra pessoa concluiu este guia.
776831
Membro desde: 06/10/21
1.085 Reputação
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 69
Duração total: 1,061
