Introdução
Impacts, caused from either being dropped or being transported, can leave the speaker guards on the Bose SoundLink Mini II dented and damaged. This can distort sound and leave the speakers more vulnerable to damage. This guide will demonstrate how to remove and replace these speaker guards to help your device look like new!
O que você precisa
Two mesh tabs hold the speaker guard in place on either end.
Use the plastic opening tool to peel away the rubber insert.
Use the metal spudger to lift one of the tabs away from the device.
To replace the speaker guard, make sure the rubber insert is in place on the back of the mesh guard.
Insert one end of the speaker guard into the frame. Then gently fit the other end of the speaker guard into the frame.
Press firmly on the speaker guard ensuring that it is properly installed.
7 outras pessoas executaram este guia.
4 comentários
Where do you buy the replacement speaker guards from? (UK)
Where do you find a spare speaker guard for the soundlink mini 2?
My mail. "engadin@gmx.ch" regards Peter
Where do I find a speaker guard for soundlink mini 2 please. Regards Peter
i have a bose soundlink mini 2, oneday i left it on and left my room. on my return i found out that it has gone off and since then it cannot turn on again. i have charged it overnight, in fact i have charged it for both short and long time but still can't turn on. when i press the power button it doesn't show any sign of booting.
can you repair my bose soundlink mini 2 for me?
