Ir para o conteúdo principal
Bose Soundlink II Battery Replacement
O que você precisa
  1. Bose Soundlink II Battery Replacement, Bose Soundlink II Cover Removal: passo 1, imagem 1 %32
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Battery Replacement: passo 2, imagem 1 %32
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Battery Replacement, Battery: passo 3, imagem 1 %32
    • Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
  4. Bose Soundlink II Battery Replacement: passo 4, imagem 1 %32 Bose Soundlink II Battery Replacement: passo 4, imagem 2 %32
    • Carefully remove the battery by pulling it out of the speaker.
Conclusão
14 outras pessoas executaram este guia.
Kevin Bailey
Membro desde: 09/24/15
464 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team 22-4, Rauch Fall 2015 Membro de Texas Tech, Team 22-4, Rauch Fall 2015
TTU-RAUCH-F15S22G4
Membros da 3
Autoria de 3 guias
11 comentários
Where i can buy one them battery model?
Daniel Campos - Responder
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
      Thanks, Bob.
bobveitch4 - Responder
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
Okenyodo Johnpaul - Responder
I bought an Replacement battery which brand is Emaks from Amazon and do it following the guide,It works well now!Thank you!!!
Emily - Responder
How much the battery only
Joboy De Guzman II - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 76
Últimos 30 dias: 260
Duração total: 32,507
