Introdução
A common issue with the Bose Soundlink Flex is its speaker. Over time, wear and tear degrade the quality of the sound the speaker produces. This guide will provide the necessary steps in replacing this component. If the speaker is in good condition, but the audio is not playing, be sure to check the Bluetooth connnection and reboot if necessary. If the Bluetooth is not working, be sure the speaker is turned on and in pair mode by going into the device settings on the device you wish to pair.
O que você precisa
Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
Lift the driver out, being cautious of the wires still connected to the device.
