Ir para o conteúdo principal
Bose SoundTouch Portable Speaker Replacement
O que você precisa
  1. Bose SoundTouch Portable Speaker Replacement, Speaker Battery: passo 1, imagem 1 %32
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Speaker Replacement: passo 2, imagem 1 %32
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Speaker Replacement: passo 3, imagem 1 %32
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Speaker Replacement, Grille: passo 4, imagem 1 %32
    • Remove the two screws holding the speaker grille in place.
  5. Bose SoundTouch Portable Speaker Replacement: passo 5, imagem 1 %32
    • Grip the sides of the device and push the speaker grille down and out.
  6. Bose SoundTouch Portable Speaker Replacement: passo 6, imagem 1 %32
    • Gently release the ribbon from its connector and remove the grille.
  7. Bose SoundTouch Portable Speaker Replacement, Speakers: passo 7, imagem 1 %32
    • There are four T-10 Torx screws for each speaker; remove all four screws for each speaker you are replacing.
  8. Bose SoundTouch Portable Speaker Replacement: passo 8, imagem 1 %32 Bose SoundTouch Portable Speaker Replacement: passo 8, imagem 2 %32 Bose SoundTouch Portable Speaker Replacement: passo 8, imagem 3 %32
    • Using a plastic pry tool, carefully pry the speaker up.
    • With the bottom of the speaker exposed, unwind the wires from the connection tabs and replace the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Chelsea Martin
Membro desde: 02/20/17
697 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S1-G3, Leahy Spring 2017 Membro de USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,829
