Ir para o conteúdo principal
Bose SoundTouch Portable Motherboard Replacement
O que você precisa
  1. Bose SoundTouch Portable Motherboard Replacement, Speaker Battery: passo 1, imagem 1 %32
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Motherboard Replacement: passo 2, imagem 1 %32
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Motherboard Replacement, Metal Trim: passo 4, imagem 1 %32
    • Remove the two screws using a torx screwdriver.
  5. Bose SoundTouch Portable Motherboard Replacement: passo 5, imagem 1 %32
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  6. Bose SoundTouch Portable Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Bose SoundTouch Portable Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove four T-10 Torx screws; there are two on the front and two on the back.
  7. Bose SoundTouch Portable Motherboard Replacement: passo 7, imagem 1 %32 Bose SoundTouch Portable Motherboard Replacement: passo 7, imagem 2 %32 Bose SoundTouch Portable Motherboard Replacement: passo 7, imagem 3 %32
    • Pinch and remove the connectors.
    • Use a flat tool to pry off the top piece.
  8. Bose SoundTouch Portable Motherboard Replacement: passo 8, imagem 1 %32 Bose SoundTouch Portable Motherboard Replacement: passo 8, imagem 2 %32 Bose SoundTouch Portable Motherboard Replacement: passo 8, imagem 3 %32
    • Remove the four T-10 Torx screws holding the plastic cover in place.
    • Remove the one T-10 Torx screw that is holding the motherboard in place.
    • Pry off the motherboard.
Conclusão
Chelsea Martin
Membro desde: 02/20/17
697 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S1-G3, Leahy Spring 2017 Membro de USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 2,999
