Ir para o conteúdo principal
Bose SoundLink Mini Front/Back Protective Grille Replacement
O que você precisa
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: passo 1, imagem 1 %32
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 2, imagem 1 %32 Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 2, imagem 2 %32
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 3, imagem 1 %32 Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 3, imagem 2 %32
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 4, imagem 1 %32 Bose SoundLink Mini Front/Back Protective Grille Replacement: passo 4, imagem 2 %32
    • Repeat steps to remove the back grille.
Conclusão
9 outras pessoas executaram este guia.
Jordan Smith
Membro desde: 10/01/15
895 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-23, Maness Fall 2015 Membro de Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
Membros da 4
Autoria de 21 guias
6 comentários
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - Responder
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - Responder
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - Responder
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 100
Duração total: 12,773
