O que você precisa
Start by pulling on the outer edges of the rubber part on the bottom of the enclosure.
Note that it will not detach completely from the enclosure.
To reassemble your device, follow the instructions in reverse order.
8 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
3 comentários
Please be advised that the Bose support website has a firmware update that fixes some battery issues. I took my dead - non-charging Soundlink Color II apart and then found the website and fixed the issue with the firmware update! The update website is located @ http://btu.bose.com
Beware that, after the battery gets undervolted (like 2.4V), the device does not seem to accept an externally charged battery and continues to act dead, until it finds some form of comfort over its USB input. Not from a dumb 5V power supply, but from an USB charger or PC supporting some level of power delivery extension, and an appropriately wired lead.
Please list type of battery and where to find it it took me a while to find it
