Ir para o conteúdo principal
Bose SoundLink Color Button Pad Replacement
O que você precisa
  1. Bose SoundLink Color  Button Pad Replacement, Outer Casing: passo 1, imagem 1 %32 Bose SoundLink Color  Button Pad Replacement, Outer Casing: passo 1, imagem 2 %32
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
  2. Bose SoundLink Color  Button Pad Replacement: passo 2, imagem 1 %32 Bose SoundLink Color  Button Pad Replacement: passo 2, imagem 2 %32
    • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
    • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
  3. Bose SoundLink Color  Button Pad Replacement: passo 3, imagem 1 %32 Bose SoundLink Color  Button Pad Replacement: passo 3, imagem 2 %32
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
  4. Bose SoundLink Color  Button Pad Replacement, Button Pad: passo 4, imagem 1 %32 Bose SoundLink Color  Button Pad Replacement, Button Pad: passo 4, imagem 2 %32
    • Lift up the retaining flap on the button cable ZIF connector.
    • Pull the button cable straight out of the connector.
  5. Bose SoundLink Color  Button Pad Replacement: passo 5, imagem 1 %32 Bose SoundLink Color  Button Pad Replacement: passo 5, imagem 2 %32
    • Carefully pull the ribbon cable through the rubber gasket that runs around the device.
  6. Bose SoundLink Color  Button Pad Replacement: passo 6, imagem 1 %32
    • To remove the old rubber button pad, carefully peel it off of the blue casing.
Conclusão
To reassemble your device, follow these instructions in reverse order, starting from Step 6.
8 outras pessoas executaram este guia.
3 comentários
Great guide, and I think I can manage this. But, where can I get the Replacement Bose SoundLink Color Button Pad??
Fred
Fred Fish - Responder
I’m wondering the same thing. Where do you get the replacement Bose Soundlink Color button pad? We just bought a new charger because we thought that was the problem. But that didn’t make any difference. We still can’t turn the speaker on!
Lynn Wilson - Responder
I got the bose soundlink color button panel only with bose India authorised service center in South Mumbai . That cost me in Indian RS. 2360. Including approx $35 USD.
nrirehan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 52
Duração total: 10,034
