Ir para o conteúdo principal
Bose SoundDock Portable v2 Remote Battery Replacement
O que você precisa
  1. Bose SoundDock Portable v2 Remote Battery Replacement, Remote Battery: passo 1, imagem 1 %32
    • Using a quarter, turn the battery cover 1/8th of a turn counterclockwise.
  2. Bose SoundDock Portable v2 Remote Battery Replacement: passo 2, imagem 1 %32 Bose SoundDock Portable v2 Remote Battery Replacement: passo 2, imagem 2 %32
    • Remove cover and battery. The new battery should be placed with the positive (flat) side facing up.
    • The correct battery for your remote is a CR2032. You may also use a DL2032.
Conclusão
Equipe
Cal Poly, Team 4-1, Maness Spring 2015 Membro de Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
Membros da 4
Autoria de 5 guias
Um comentário
We have a Bose Wave radio w/remote. This remote is not the one shown here with a screw for the battery compartment. It's the type w/a sliding holder for the battery on the south end (bottom of the battery). Someone went to replace the battery and shoved the holder in upside down I believe. Consequently the holder will not come out all the way.
There must be a way to get it out without forcing it. There's a pinch clip you have to either squeeze or move to the left to disengage it from the locked position and free it up. Any ideas as to how to accomplish this? We appreciate a reply back so this would make our Christmas better.
Merry Christmas & Happy Holidays! Cheers!
asbirdiesingh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 136
Duração total: 13,492
