Ir para o conteúdo principal
Bose Solo 5 Sound Bar Indicator Light Replacement
O que você precisa
  1. Bose Solo 5 Sound Bar Indicator Light Replacement, Indicator Light: passo 1, imagem 1 %32
    • Lay the Bose Solo 5 on its side, with the speakers facing away from you. This orientation will result in the bottom of the speaker facing upwards.
  2. Bose Solo 5 Sound Bar Indicator Light Replacement: passo 2, imagem 1 %32
    • Remove five 18.25mm screws with a Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Indicator Light Replacement: passo 3, imagem 1 %32
    • Gently remove the gold plates and the snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Indicator Light Replacement: passo 4, imagem 1 %32
    • Using the plastic opening tool, slightly lift the circuit board up and remove it from the housing.
  5. Bose Solo 5 Sound Bar Indicator Light Replacement: passo 5, imagem 1 %32
    • Disconnect the cords running to the white connector by pulling upon the tab until it is disconnected completely.
  6. Bose Solo 5 Sound Bar Indicator Light Replacement: passo 6, imagem 1 %32
    • Locate the two clear LED receptors and note that one has two prongs and the other has three prongs.
  7. Bose Solo 5 Sound Bar Indicator Light Replacement: passo 7, imagem 1 %32 Bose Solo 5 Sound Bar Indicator Light Replacement: passo 7, imagem 2 %32
    • Locate on the back of the control panel where it states LED 902, 903, 904, and 905.
  8. Bose Solo 5 Sound Bar Indicator Light Replacement: passo 8, imagem 1 %32 Bose Solo 5 Sound Bar Indicator Light Replacement: passo 8, imagem 2 %32
    • If there is any debris located in these locations, use the spudger tool to thoroughly clean the area.
Conclusão
To reassemble the sound bar, follow the steps listed above in reverse order.
Uma outra pessoa concluiu este guia.
Emma
Membro desde: 10/05/18
500 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 5,572
