Ir para o conteúdo principal
Bose Solo 5 Sound Bar Control Panel Replacement
O que você precisa
  1. Bose Solo 5 Sound Bar Control Panel Replacement, Control Panel: passo 1, imagem 1 %32
    • Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
  2. Bose Solo 5 Sound Bar Control Panel Replacement: passo 2, imagem 1 %32 Bose Solo 5 Sound Bar Control Panel Replacement: passo 2, imagem 2 %32
    • Remove the five 18.25mm screws with the Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Control Panel Replacement: passo 3, imagem 1 %32
    • Remove the gold plates snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Control Panel Replacement: passo 4, imagem 1 %32
    • Using the plastic opening tool, lift the circuit board up and remove from housing.
  5. Bose Solo 5 Sound Bar Control Panel Replacement: passo 5, imagem 1 %32 Bose Solo 5 Sound Bar Control Panel Replacement: passo 5, imagem 2 %32
    • Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
Conclusão
Uma outra pessoa concluiu este guia.
Emma
Membro desde: 10/05/18
500 Reputação
Autoria de 3 guias
Equipe
5 comentários
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
Tyler Barney - Responder
hallo und wo bekomme ich das Ersatzteil die Platiene 73252 Delta 3
APP TISCHNER - Responder
Has anyone had any luck finding the same board. Im looking.
ka.wells - Responder
I know how to open it. What I don't know is where to buy one.
szanti - Responder
If anyone was able to find the board, it wuold be great to know where did you find it. Looking for this board during months...
Juan Ramirez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 99
Duração total: 13,099
