Introdução
This guide aims to provide a step-by-step process to replace an earcup, the earcup provides more insulation and helps with isolating sound in the headphones.
O que você precisa
Locate the clips where the cushion is attached and slowly detach them.
After removing the cloth you will expose a plastic plate with three 4 mm screws.
Grab your PH00 head and unscrew them.
Quase terminado!
Conclusão
