Ir para o conteúdo principal
Bose QuietComfort 35 Repairing the power button slider Replacement
O que você precisa
  1. Bose QuietComfort 35 Repairing the power button slider Replacement, Assessing the problem: passo 1, imagem 1 %32
    • These Bose headphones have a power slider on the bottom shell in the picture. After 3 or so years, the slider no longer engages, and after disassembly it can be seen that a part of the slider has broken off. This can be fixed with glue and a heat-shrink tube.
  2. Bose QuietComfort 35 Repairing the power button slider Replacement, Removing the pad and opening the cloth: passo 2, imagem 1 %32 Bose QuietComfort 35 Repairing the power button slider Replacement, Removing the pad and opening the cloth: passo 2, imagem 2 %32 Bose QuietComfort 35 Repairing the power button slider Replacement, Removing the pad and opening the cloth: passo 2, imagem 3 %32
    • ... as seen on Youtube: remove the earpads by gently pulling, they are held in place by clips.
    • Then remove the cloth; it has been glued, but can be pried off. Opening a single edge is sufficient to find the three screws.
    • Minor tears are no concern; in this case when reassembling, double sided sticky tape has been used.
  3. Bose QuietComfort 35 Repairing the power button slider Replacement, Opening the shell: passo 3, imagem 1 %32 Bose QuietComfort 35 Repairing the power button slider Replacement, Opening the shell: passo 3, imagem 2 %32 Bose QuietComfort 35 Repairing the power button slider Replacement, Opening the shell: passo 3, imagem 3 %32
    • The shell is held in place by three phillips screws, see photos. Then the shell at the back can gently be pried off.
    • it may be helpful to use tape to pull the shell. Whilst opening, the power slide and the bit that broke of fell out.
  4. Bose QuietComfort 35 Repairing the power button slider Replacement: passo 4, imagem 1 %32 Bose QuietComfort 35 Repairing the power button slider Replacement: passo 4, imagem 2 %32 Bose QuietComfort 35 Repairing the power button slider Replacement: passo 4, imagem 3 %32
    • Glueing the broken part in place with instant glue restores the shape; here an additional heat shrink tube has been added for extra strength.
    • Gently heat the tube so that it pulls the part in place.
    • Also, the instant gluemade the opening a bit more narrow than original, so some smal torx have been used to widen the hole a bit. A very small drill would work as well.
  5. Bose QuietComfort 35 Repairing the power button slider Replacement: passo 5, imagem 1 %32
    • Place the sider back, where the knop is oriented towards the centre of the headphone shell.
Conclusão
7 outras pessoas executaram este guia.
10Comentários do guia
This fix in this video is not very well done. Not explained well enough!
Marly Marls - Responder
Let me know where you get stuck, and what you miss.
Pieter van der Wolk -
Hi, can I get a quick repair from you with pay if I come to your location? Please give me your number
Zehal Khosraw - Responder
I recommend repair café's https://www.repaircafe.org for that, I volunteer in one.
Do you have a part number for the power switch or offer a replacement? My Quiet Comforts turn themselves on intermittently so I often find the battery dead when I need to use them.
maginhome - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 59
Últimos 30 dias: 316
Ao todo: 12,056
