Ir para o conteúdo principal
Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement
O que você precisa
  1. Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement, Ear Cushion and Scrim Mat: passo 1, imagem 1 %32
    • Slide the power button to the "off" position.
    • The power light color should be red.
  2. Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 2, imagem 1 %32 Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 2, imagem 2 %32 Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 2, imagem 3 %32
    • Firmly squeeze the torn portion of the ear cushion while grasping the plastic ear cup.
    • Pull the cushion toward the center and up to remove them from the fasteners.
    • Repeat this on all sides of the cushion until it's freed from the ear cup.
    • Repeat the above steps for the second ear cushion.
  3. Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 3, imagem 1 %32 Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 3, imagem 2 %32 Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 3, imagem 3 %32
    • Take the top end of the scrim mat while firmly holding the plastic earcup.
    • Peel it back and away from the plastic to break the adhesive and remove it from the ear cup.
    • Repeat the above steps with the second scrim mat.
  4. Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 4, imagem 1 %32 Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 4, imagem 2 %32
    • Using your fingernail or a spudger, to scrape away remnants of the scrim mat from both sides of the plastic earcup.
    • Use a paper towel dipped in rubbing alcohol to scrub any excess adhesive from the plastic earcup.
    • Do not soak the paper towel as too much rubbing alcohol could flood the exposed speakers and interior electronics within the earcup permanently damaging them.
  5. Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 5, imagem 1 %32 Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 5, imagem 2 %32 Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 5, imagem 3 %32
    • Holding the replacement scrim mat firmly, peel the tab covering the new adhesive on each side of the new scrim mat.
    • Place the new scrim mat inside the empty earcup, covering the exposed speaker and interior electronics.
    • Repeat the above steps with the second replacement scrim mat.
    • It is easy to place the new scrim mats in the wrong earcup. The scrim mat labeled R should be placed in the earcup that has the power switch. The scrim mat labeled L goes in the opposite earcup.
    • A tiny R and L is also inscribed within the earcup.
  6. Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 6, imagem 1 %32 Bose QuietComfort 35 Earpad Cushion and Scrim Mat Replacement: passo 6, imagem 2 %32
    • On the inside rim of the earcup, there are small clips.
    • Align the cushion with the ear cup, and expose the plastic ring underneath the cushion by pulling the cushion back slightly.
    • Slide and press the plastic ring into the first clip until you hear a clicking sound. Repeat for the remaining clips.
    • Every time you insert a part of the cushion's plastic ring under one of the clips, you will hear a clicking sound which means it has been successfully placed behind the clip.
    • Confirm that the ear cushions are secure.
Conclusão
7 outras pessoas executaram este guia.
Cole Bianchi
Membro desde: 01/26/23
217 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-9, Morris Winter 2023 Membro de UC Davis, Team 2-9, Morris Winter 2023
UCD-MORRIS-W23S2G9
Membros da 2
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 54
Últimos 30 dias: 374
Duração total: 4,810
