Ir para o conteúdo principal
Bose QuietComfort 25 Ear Cushion Replacement
O que você precisa
  1. Bose QuietComfort 25 Ear Cushion Replacement, Ear Cushion: passo 1, imagem 1 %32
    • Firmly grasp the ear cushion.
    • Remove the ear cushion by slowly pulling the cushion up and away from the Bose QuietComfort 25.
    • The cushion will suddenly come loose from the plastic fasteners. Maintain a firm grasp on the Bose QuietComfort 25 to ensure that it does not slip and break.
  2. Bose QuietComfort 25 Ear Cushion Replacement: passo 2, imagem 1 %32 Bose QuietComfort 25 Ear Cushion Replacement: passo 2, imagem 2 %32
    • Lay the replacement ear cushion on top of the earphone.
    • The plastic bottom edge of the ear cushion should align with the circumference of the earphone.
    • Using an iFixit opening tool (or your finger or nail), push down on the plastic edge of the ear cushion to fit it under the nine plastic fasteners on the inside of the earphone.
    • After the ear cushion is in place, the nine fasteners should be visible if you pull the cushion to the center of the earphone.
Conclusão
You have correctly replaced your old, broken ear cushions with a new pair. Have fun and enjoy your music!
17 outras pessoas executaram este guia.
Um comentário
Great write up, saved me from having to buy new headphones. Just to add some clarification for the Bose QuietComfort 35, the right side is the side with the buttons (if you get mixed up like I did).
Bassdrumer2 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 116
Duração total: 11,871
