Ir para o conteúdo principal
Bose Cinemate 10 Subwoofer Replacement
O que você precisa
  1. Bose Cinemate 10 Subwoofer Replacement, End Cap: passo 1, imagem 1 %32 Bose Cinemate 10 Subwoofer Replacement, End Cap: passo 1, imagem 2 %32
    • Using the blue plastic opening tool, pry up on the cloth covered end panel. The edge of end cap cover should separate from main body of device.
  2. Bose Cinemate 10 Subwoofer Replacement: passo 2, imagem 1 %32
    • Using your fingers, lift up on the end cap cover until it separates completely from the main body of the device.
  3. Bose Cinemate 10 Subwoofer Replacement: passo 3, imagem 1 %32 Bose Cinemate 10 Subwoofer Replacement: passo 3, imagem 2 %32
    • Remove the 4, PH1, 15mm screws on the side speaker cover frame.
  4. Bose Cinemate 10 Subwoofer Replacement: passo 4, imagem 1 %32
    • Remove speaker cover frame from main body of device.
  5. Bose Cinemate 10 Subwoofer Replacement, Subwoofer: passo 5, imagem 1 %32 Bose Cinemate 10 Subwoofer Replacement, Subwoofer: passo 5, imagem 2 %32
    • Remove the 4, PH1, 10 mm screws from the subwoofer frame.
  6. Bose Cinemate 10 Subwoofer Replacement: passo 6, imagem 1 %32 Bose Cinemate 10 Subwoofer Replacement: passo 6, imagem 2 %32
    • Using the blue plastic opening tool, pry up on the edge of the subwoofer frame.
    • Using your fingers, lift up on the subwoofer frame until it separates completely from the main body of the device.
  7. Bose Cinemate 10 Subwoofer Replacement: passo 7, imagem 1 %32 Bose Cinemate 10 Subwoofer Replacement: passo 7, imagem 2 %32 Bose Cinemate 10 Subwoofer Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the curved precision tweezers, grasp end of wire.
    • Using the curved precision tweezers, unravel wire around blue metal post.
  8. Bose Cinemate 10 Subwoofer Replacement: passo 8, imagem 1 %32 Bose Cinemate 10 Subwoofer Replacement: passo 8, imagem 2 %32
    • After wire is completely unraveled, repeat steps 4 and 5, on red metal post.
    • Remove the speaker from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 1,369
