Ir para o conteúdo principal
Bosch PS21 Gearbox (Clutch) Replacement
O que você precisa
  1. Bosch PS21 Gearbox (Clutch) Replacement, Battery: passo 1, imagem 1 %32
    • Pinch the two release tabs on the sides of the battery, and slide the battery out.
  2. Bosch PS21 Gearbox (Clutch) Replacement, Gearbox: passo 2, imagem 1 %32 Bosch PS21 Gearbox (Clutch) Replacement, Gearbox: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    $3.99
    • Locate the clip that binds the two halves of the outer casing together on the rear edge of the battery shaft. Remove the clip with the angled tweezers.
  3. Bosch PS21 Gearbox (Clutch) Replacement: passo 3, imagem 1 %32
    • Locate the eight 5.5 mm screws on the upwards facing side of the drill.
    • Remove each screw using the T8 Torx screwdriver and place them together in a safe place.
  4. Bosch PS21 Gearbox (Clutch) Replacement: passo 4, imagem 1 %32 Bosch PS21 Gearbox (Clutch) Replacement: passo 4, imagem 2 %32
    • Remove the upper portion of the case from the outer portion of the case using a metal spudger.
  5. Bosch PS21 Gearbox (Clutch) Replacement: passo 5, imagem 1 %32 Bosch PS21 Gearbox (Clutch) Replacement: passo 5, imagem 2 %32
    • Dislodge the motor assembly from the casing.
    • Remove the gearbox from the motor assembly.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
IUPUI, Team 1-2, Harley Spring 2016 Membro de IUPUI, Team 1-2, Harley Spring 2016
IUPUI-HARLEY-S16S1G2
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 26
Ao todo: 3,908
