Ir para o conteúdo principal
Bosch PS21 Battery Replacement
O que você precisa
  1. Bosch PS21 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Pinch the two release tabs on the sides of the battery, and slide the battery out.
    If you look at the "tools required" here you'll see torx screwdriver, needle nose pliers, tweezers, etc. So whoever started putting this together probably intended to show how to replace the batter cells inside the casing. But those steps are missing. If anyone has a guide to how to actually fix bad cells for this specific battery, please share!
    George Mann - Responder
Conclusão
Lillie Wolter
Membro desde: 02/15/16
128 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 1-2, Harley Spring 2016 Membro de IUPUI, Team 1-2, Harley Spring 2016
IUPUI-HARLEY-S16S1G2
Membros da 4
Autoria de 4 guias
Um comentário
I really appreciate this guide. I would have never know how to do this without this guide
Derek Lechner - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 3,537
