Introdução
Use this guide to replace the battery in the Bosch PS21.
O que você precisa
Pinch the two release tabs on the sides of the battery, and slide the battery out.
Quase terminado!
Conclusão
Um comentário
I really appreciate this guide. I would have never know how to do this without this guide
If you look at the "tools required" here you'll see torx screwdriver, needle nose pliers, tweezers, etc. So whoever started putting this together probably intended to show how to replace the batter cells inside the casing. But those steps are missing. If anyone has a guide to how to actually fix bad cells for this specific battery, please share!
George Mann - Responder
