Introdução
Your plug is damaged on your Bosch PMF 180 E? With this guide, you can exchange it!
O que você precisa
Repeat the steps in order to reassemble your device.
Um agradecimento especial a esses tradutores:
100%
irlanda está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Documentos anexados
Um comentário
To right of green holder there is a looped black and white wire that goes underneath. Where does it attach to as mine is loose below coil, between coil and case. Tool just stopped working mid use. No burning smell and no other loose connections. There is a moulding.on case that it fits into but no attachment anywhere. Coil has a small dent where small bend in wire appears to have sat
