Introdução
The oven in my Bosch gas range did not heat. It clicked when I started it, and the electronic panel behaved normally (but it never got past 'preheating'.)
The stovetop gas burners worked fine so I know the range had gas. Also the broiler lit, although the broiler flame is hard to see.
I didn’t do this repair, but now I wish I had. I called the service technician. He looked at it for 1 minute and replaced the ‘Igniter’. It was an easy repair for him and cost me $400 including the service call and the $170 part. He said the igniter is a ‘wear-out’ part.
Before the technician replaced the igniter he did a test of the old one with a clamp-on Ammeter. He held in the door-closed switch at the top to test it. I didn't see exactly what he checked, I wish I had, He told me that if the gas does not get lit within a few seconds then the gas supply is shut down for safety.
I see the genuine part is part AP5809118 available for $109 online.
I am writing this guide to help others to fix their own Bosch gas oven.
After I wrote this I received a great comment, here it is:
I've worked on appliances for over 25 years. One thing you left out is that you could have put in a Frigidaire brand ignitor (part number 5303935066) and gotten the same results. A square ignitor is a square ignitor no matter the brand. The Frigidaire ignitor can be found online for $20 or less.
Thom Scott
O que você precisa
Open the oven door to its fully open, horizontal position.
Flip levers on hinges toward you. Note: It may be necessary to use a tool, such as a screwdriver, to gently pry the upper part of the lever away from the housing. Take care to avoid scratching the housing.
Bring both door hinge levers to their fullest down position as shown in the illustration. The left and right door hinge levers may differ slightly but operate in the same manner.
Close the oven door until it catches on the hinge stop levers, locking the hinges at the proper angle for door removal. The door will be open about 7 inches at the top. This takes the spring tension off the hinges so the door can be easily lifted out.
Place the door in a convenient and stable location for cleaning.
The oven gas burner and the igniter are under the panel at the bottom of the oven.
Remove the two screws at the back of the oven and pull up on the bottom panel to remove.
Set the panel aside.
The igniter is about 3-inches long, with two pre-stripped wires coming off it.
Remove the old igniter by removing the two holding screws, and disconnecting the wire-nuts that connect it.
Install the new igniter by reversing these directions.
7Comentários do guia
Thom Scott
Thanks Thom. I had no idea, but that makes a lot of sense. Jim J
My screws 100% rusted on. Fused with the metal. Is there a entire stovetop assembly that can be purchased?
I have no idea. I would try to drill the rusted screws out with an electric drill.
I pulled out the igniter but the two wires are still plugged in somewhere that's not visible. How do you get to the location where the igniter plugs in?
