Introdução
Purchase a new On/Off Switch. The sander should be unplugged from any power sources. Make sure you organize the removed screws, so you can reinstall them in the correct location.
O que você precisa
Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
Lift the top cover off the sander.
Ferramenta utilizada nesse passo:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch.
Uma outra pessoa concluiu este guia.
