Ir para o conteúdo principal
Bosch 3727DEVS Governor Replacement
O que você precisa
  1. Bosch 3727DEVS Governor Replacement, Governor: passo 1, imagem 1 %32 Bosch 3727DEVS Governor Replacement, Governor: passo 1, imagem 2 %32 Bosch 3727DEVS Governor Replacement, Governor: passo 1, imagem 3 %32
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top off of the sander.
  2. Bosch 3727DEVS Governor Replacement: passo 2, imagem 1 %32 Bosch 3727DEVS Governor Replacement: passo 2, imagem 2 %32 Bosch 3727DEVS Governor Replacement: passo 2, imagem 3 %32
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift the cable clip and cord from motor housing.
  3. Bosch 3727DEVS Governor Replacement: passo 3, imagem 1 %32
    • Lift the On/Off switch out of the device
    • Remove the gray and purple wires
  4. Bosch 3727DEVS Governor Replacement: passo 4, imagem 1 %32 Bosch 3727DEVS Governor Replacement: passo 4, imagem 2 %32
    • Remove the gray, brown, and clear wires by pulling on the wire terminals.
    • Lift the Governor out of the housing.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 571
