Ir para o conteúdo principal
Boosted Board 1st Generation Belts Replacement
O que você precisa
  1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: passo 1, imagem 1 %32 Boosted Board 1st Generation Belts Replacement, Rear Wheels: passo 1, imagem 2 %32
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Belts Replacement: passo 2, imagem 1 %32
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Belts Replacement: passo 3, imagem 1 %32 Boosted Board 1st Generation Belts Replacement: passo 3, imagem 2 %32
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Belts Replacement: passo 4, imagem 1 %32 Boosted Board 1st Generation Belts Replacement: passo 4, imagem 2 %32 Boosted Board 1st Generation Belts Replacement: passo 4, imagem 3 %32
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Belts Replacement, Belts: passo 5, imagem 1 %32 Boosted Board 1st Generation Belts Replacement, Belts: passo 5, imagem 2 %32 Boosted Board 1st Generation Belts Replacement, Belts: passo 5, imagem 3 %32
    • Compress the motor mount back .
    • Slide the belt off the axle
  6. Boosted Board 1st Generation Belts Replacement: passo 6, imagem 1 %32
    • Remove the two hex screws.
    • Remove the front hex screw.
    • When removing the Front hex screw, hold the motor mount and the truck together.
    • The springs inside the motor mount will push the motor out of the casing if they are not held together.
  7. Boosted Board 1st Generation Belts Replacement: passo 7, imagem 1 %32 Boosted Board 1st Generation Belts Replacement: passo 7, imagem 2 %32 Boosted Board 1st Generation Belts Replacement: passo 7, imagem 3 %32
    • Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
    • Do Not let go of the motor and truck until the new belt is on and the Front hex screw is tightened securely.
Conclusão
4 outras pessoas executaram este guia.
Emily Imfeld
Membro desde: 10/06/16
532 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 15-7, Livingston Fall 2016 Membro de Cal Poly, Team 15-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G7
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,655
