Ir para o conteúdo principal
Body Cover Removal
O que você precisa
  1. Body Cover Removal, Remove back cover: passo 1, imagem 1 %32
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Body Cover Removal, Remove bottom cover: passo 2, imagem 1 %32
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Body Cover Removal, Remove left front cover: passo 3, imagem 1 %32
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Body Cover Removal, Remove front cover: passo 4, imagem 1 %32 Body Cover Removal, Remove front cover: passo 4, imagem 2 %32
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Body Cover Removal, Remove right front cover: passo 5, imagem 1 %32
    • Remove two 3.9 mm #00 screws.
  6. Body Cover Removal, Remove eye cup: passo 6, imagem 1 %32
    • Slide the eye cup up and off to access the screws underneath.
  7. Body Cover Removal, Unscrew top cover: passo 7, imagem 1 %32 Body Cover Removal, Unscrew top cover: passo 7, imagem 2 %32 Body Cover Removal, Unscrew top cover: passo 7, imagem 3 %32
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
  8. Body Cover Removal, Lift top cover: passo 8, imagem 1 %32
    • Lift the cover so it is just free of the body. It is still attached by several wires.
Conclusão
Sam Gustafson
Membro desde: 09/01/22
2.774 Reputação
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 205
