Ir para o conteúdo principal
Blu Studio Selfie Rear Facing Camera Replacement
O que você precisa
  1. Blu Studio Selfie Rear Facing Camera Replacement, Rear Cover: passo 1, imagem 1 %32
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Rear Facing Camera Replacement: passo 2, imagem 1 %32
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Rear Facing Camera Replacement, Battery: passo 3, imagem 1 %32 Blu Studio Selfie Rear Facing Camera Replacement, Battery: passo 3, imagem 2 %32
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
  4. Blu Studio Selfie Rear Facing Camera Replacement, Midframe: passo 4, imagem 1 %32
    • Remove all the 4mm Phillips #000 screws from the midframe.
  5. Blu Studio Selfie Rear Facing Camera Replacement: passo 5, imagem 1 %32
    • Insert the spudger between the midframe and the display assembly.
    • Gently pry up the midframe.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  6. Blu Studio Selfie Rear Facing Camera Replacement: passo 6, imagem 1 %32
    • Where the battery rested before, you will find a small clip that holds down the midframe.
    • After the rest of the midframe is detached, from the phone place the flat end of the spudger beneath the clip.
    • Gently lift up on the clip until it comes free.
    • Remove the midframe from the phone.
  7. Blu Studio Selfie Rear Facing Camera Replacement, Rear Facing Camera: passo 7, imagem 1 %32 Blu Studio Selfie Rear Facing Camera Replacement, Rear Facing Camera: passo 7, imagem 2 %32
    • Flip up the retaining flap on the camera cable ZIF connector.
    • Pull the camera's ribbon cable straight out of its socket.
    • Gently remove the rear facing camera.
Conclusão
Stacy Kam
Membro desde: 01/20/16
630 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 10-1, Remmell Spring 2016 Membro de USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 336
