Ir para o conteúdo principal
Blu Studio Selfie Battery Replacement
O que você precisa
  1. Blu Studio Selfie Battery Replacement, Rear Cover: passo 1, imagem 1 %32
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Battery Replacement: passo 2, imagem 1 %32
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Battery Replacement, Battery: passo 3, imagem 1 %32 Blu Studio Selfie Battery Replacement, Battery: passo 3, imagem 2 %32
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Stacy Kam
Membro desde: 01/20/16
630 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 10-1, Remmell Spring 2016 Membro de USF Tampa, Team 10-1, Remmell Spring 2016
USFT-REMMELL-S16S10G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,356
