Ir para o conteúdo principal
Blu Studio HD 6.0 SIM Card Replacement
O que você precisa
  1. Blu Studio HD 6.0 SIM Card Replacement, Rear Case: passo 1, imagem 1 %32
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 SIM Card Replacement, Back Panel.: passo 2, imagem 1 %32 Blu Studio HD 6.0 SIM Card Replacement, Back Panel.: passo 2, imagem 2 %32
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 SIM Card Replacement: passo 3, imagem 1 %32 Blu Studio HD 6.0 SIM Card Replacement: passo 3, imagem 2 %32
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 SIM Card Replacement, Find out if your Blu Studio 6.0 is "unlocked.": passo 4, imagem 1 %32
    • Look at the sticker on top of the battery housing and note the model, part number and type.
    • Research this information to find out if you have an unlocked version of the phone.
    • If your phone is unlocked you can use any mobile network SIM card. If not you must replace the SIM card with a card from your carrier.
  5. Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: passo 5, imagem 1 %32 Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: passo 5, imagem 2 %32 Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: passo 5, imagem 3 %32
    • If necessary slide the unneeded SIM card out of it's slot.
    • Make sure your new SIM card has been activated by the carrier.
    • Take the front end tip of the SIM card (the side with the corner cut) and slide it gently into the SIM card slot.
  6. Blu Studio HD 6.0 SIM Card Replacement, Turn the phone on: passo 6, imagem 1 %32
    • Turn on your Studio 6.0 and test it to make sure that everything is working.
    • If your phone gives you an error, check your SIM card installation. If everything seems to be correct make sure your SIM card is activated.
    • If everything is working you're good to go.
Conclusão
7 outras pessoas executaram este guia.
Alec
Membro desde: 09/23/14
617 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 9-1, Blackwell Fall 2014 Membro de USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
Membros da 3
Autoria de 8 guias
13 comentários
Okay so my Sim has been working for months just 2 days ago my phone wouldn't turn on and then we'll now it doesn't read the Sim card idk what's going on with this but its getting annoying
caitlin - Responder
i know i am having the same issue. it is saying my sim card is off and to turn it on
jsllndr84 -
Its saying my Sim card is off..how do I turn it on.
victor ayitey - Responder
I just got this phone and I install the sim card like they say and it still says no sim card
Cheryl Dean - Responder
I have activated metro pcs sim. Unlocked blu studio g2 6.0 will not detect sim wtf?
Tim - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 44,777
