Ir para o conteúdo principal
Blu Studio HD 6.0 Microphone Replacement
O que você precisa
  1. Blu Studio HD 6.0 Microphone Replacement, Rear Case: passo 1, imagem 1 %32
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Microphone Replacement, Back Panel.: passo 2, imagem 1 %32 Blu Studio HD 6.0 Microphone Replacement, Back Panel.: passo 2, imagem 2 %32
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Microphone Replacement: passo 3, imagem 1 %32 Blu Studio HD 6.0 Microphone Replacement: passo 3, imagem 2 %32
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 Microphone Replacement, Midframe: passo 4, imagem 1 %32 Blu Studio HD 6.0 Microphone Replacement, Midframe: passo 4, imagem 2 %32
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  5. Blu Studio HD 6.0 Microphone Replacement: passo 5, imagem 1 %32
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
  6. Blu Studio HD 6.0 Microphone Replacement: passo 6, imagem 1 %32
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  7. Blu Studio HD 6.0 Microphone Replacement: passo 7, imagem 1 %32
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
  8. Blu Studio HD 6.0 Microphone Replacement, Locate the microphone.: passo 8, imagem 1 %32 Blu Studio HD 6.0 Microphone Replacement, Locate the microphone.: passo 8, imagem 2 %32
    • The microphone is located at the rear-lower-left corner.
    Is there one mic on this blu studio6.0 phone my loud speaker works but I can't hear the other person when I get incoming call from my ear mic I replace this mic twice I have to turn the speaker to answer calls in coming calls
    mauriceboyd - Responder
  9. Blu Studio HD 6.0 Microphone Replacement, Separate the old microphone.: passo 9, imagem 1 %32 Blu Studio HD 6.0 Microphone Replacement, Separate the old microphone.: passo 9, imagem 2 %32
    • Lift the microphone very carefully.
    • Unsolder the two lower wires ( one red wire and one black wire ).
  10. Blu Studio HD 6.0 Microphone Replacement, Solder the new microphone.: passo 10, imagem 1 %32
    • Solder the new microphone in the same spot. The black wire will go in the lower spot and the red wire in the upper spot.
Conclusão
6 outras pessoas executaram este guia.
Ernesto Diaz
Membro desde: 09/23/14
1.759 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 9-1, Blackwell Fall 2014 Membro de USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
Membros da 3
Autoria de 8 guias
2 comentários
Where can I get a blue microphone for my BLU phone. When I answer my BLU phone I can't hear the person on the other line but they cannot hear me so I believe it's just my microphone when I speak.
Christina - Responder
Where can I buy microphones
b langdon - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 13,586
