Ir para o conteúdo principal
Blu Studio 5.5 S Front Facing Camera Replacement
O que você precisa
  1. Blu Studio 5.5 S Front Facing Camera Replacement, Back Casing: passo 1, imagem 1 %32
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: passo 2, imagem 1 %32 Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: passo 2, imagem 2 %32 Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: passo 2, imagem 3 %32
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Front Facing Camera Replacement, Battery: passo 3, imagem 1 %32 Blu Studio 5.5 S Front Facing Camera Replacement, Battery: passo 3, imagem 2 %32 Blu Studio 5.5 S Front Facing Camera Replacement, Battery: passo 3, imagem 3 %32
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: passo 4, imagem 1 %32 Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: passo 4, imagem 2 %32 Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: passo 4, imagem 3 %32
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Front Facing Camera Replacement, Aesthetic Bottom Case: passo 5, imagem 1 %32
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Front Facing Camera Replacement: passo 6, imagem 1 %32 Blu Studio 5.5 S Front Facing Camera Replacement: passo 6, imagem 2 %32 Blu Studio 5.5 S Front Facing Camera Replacement: passo 6, imagem 3 %32
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Front Facing Camera Replacement, Frontward Facing Camera: passo 7, imagem 1 %32 Blu Studio 5.5 S Front Facing Camera Replacement, Frontward Facing Camera: passo 7, imagem 2 %32
    • The frontward facing camera is located in the top left of the phone. It is connected to the motherboard by a ribbon connector, and a prong system.
    • Use a spudger to detach the front facing camera by flipping the orange tab on the top of the prong system.
    • Once the orange tab is up, pull out the orange ribbon wire.
  8. Blu Studio 5.5 S Front Facing Camera Replacement: passo 8, imagem 1 %32 Blu Studio 5.5 S Front Facing Camera Replacement: passo 8, imagem 2 %32
    • Use tweezers to pick up the ribbon wire, and lift. The frontward facing camera will follow suit.
Conclusão
Cody Dyl
Membro desde: 10/27/14
804 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 4-8, Miles Fall 2014 Membro de UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
Membros da 2
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,548
