Ir para o conteúdo principal
Blu Studio 5.5 S Battery Replacement
  1. Blu Studio 5.5 S Battery Replacement, Back Casing: passo 1, imagem 1 %32
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Battery Replacement, Applying Pressure: passo 2, imagem 1 %32 Blu Studio 5.5 S Battery Replacement, Applying Pressure: passo 2, imagem 2 %32 Blu Studio 5.5 S Battery Replacement, Applying Pressure: passo 2, imagem 3 %32
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Battery Replacement, Battery: passo 3, imagem 1 %32 Blu Studio 5.5 S Battery Replacement, Battery: passo 3, imagem 2 %32 Blu Studio 5.5 S Battery Replacement, Battery: passo 3, imagem 3 %32
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
Conclusão
7 outras pessoas executaram este guia.
Cody Dyl
Membro desde: 10/27/14
804 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 4-8, Miles Fall 2014 Membro de UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
Membros da 2
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 6,138
