Introdução
In this guide, we will be removing the micro usb port and the circuit board it is attached to, so that a new one may be installed.
O que você precisa
Passo 1 Battery
Cuidado: as etapas de 1 a 2 são provenientes de um guia marcado como em andamento.
Flip over your Studio 5.5 so the back is facing you.
Use either the spudger or your fingernail to pull up on the slot in the lower left corner and remove the back cover.
Begin by removing the 12 screws along the back of the device.
1 of these screws will be underneath a white sticker. Just press the screwdriver through it and remove it normally.
6 outras pessoas executaram este guia.
3 comentários
i want buy chargin port sir my blue cahrging port was dead plz help me i want buy
Where do i buy the %#*@ micro usb port
