Ir para o conteúdo principal
Blu Studio 5.5 Micro USB Port Replacement
O que você precisa
  1. Cuidado: as etapas de 1 a 2 são provenientes de um guia marcado como em andamento.
    Blu Studio 5.5 Micro USB Port Replacement, Battery: passo 1, imagem 1 %32
    • Flip over your Studio 5.5 so the back is facing you.
    • Use either the spudger or your fingernail to pull up on the slot in the lower left corner and remove the back cover.
  2. Blu Studio 5.5 Micro USB Port Replacement: passo 2, imagem 1 %32 Blu Studio 5.5 Micro USB Port Replacement: passo 2, imagem 2 %32
    • Place your finger in the small groove beneath the battery.
    • Push the battery toward the top of the phone and lift it out.
  3. Blu Studio 5.5 Micro USB Port Replacement, Micro USB Port: passo 3, imagem 1 %32
    • Begin by removing the 12 screws along the back of the device.
    • 1 of these screws will be underneath a white sticker. Just press the screwdriver through it and remove it normally.
    • 5 of these screws are 3.5mm, while the remaining 7 are 5mm.
  4. Blu Studio 5.5 Micro USB Port Replacement: passo 4, imagem 1 %32 Blu Studio 5.5 Micro USB Port Replacement: passo 4, imagem 2 %32
    • Using your plastic opening tool, begin carefully prying the plastic shell from the phone.
    • Make your way around the edge slowly and lift the shell off when you have made a full circuit.
  5. Blu Studio 5.5 Micro USB Port Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using your tweezers, locate the small gold-colored plug in the bottom left corner and pull it straight out.
  6. Blu Studio 5.5 Micro USB Port Replacement: passo 6, imagem 1 %32
    • Use the tweezers again to pull out a small black plug in the bottom middle.
  7. Blu Studio 5.5 Micro USB Port Replacement: passo 7, imagem 1 %32
    • Grip the entire circuit board firmly with your tweezers and pull it towards the bottom of the phone and out.
  8. Blu Studio 5.5 Micro USB Port Replacement: passo 8, imagem 1 %32
    • Pry the speaker from the phone with your tweezers.
    • The speaker is glued to the rest of the phone and soldered to the circuit board.
Conclusão
6 outras pessoas executaram este guia.
Brian Sullivan
Membro desde: 10/22/14
647 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-2, Shastany Fall 2014 Membro de UMass Dartmouth, Team 1-2, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G2
Membros da 3
Autoria de 3 guias
3 comentários
Should I change the other parts aswell?
branfay1 - Responder
i want buy chargin port sir my blue cahrging port was dead plz help me i want buy
muhammadfaisalkhan98 - Responder
Where do i buy the %#*@ micro usb port
PoPeYe MaStEr - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 4,331
