Ir para o conteúdo principal
Blu Studio 5.5 Camera Replacement
O que você precisa
  1. Cuidado: as etapas de 1 a 2 são provenientes de um guia marcado como em andamento.
    Blu Studio 5.5 Camera Replacement, Battery: passo 1, imagem 1 %32
    • Flip over your Studio 5.5 so the back is facing you.
    • Use either the spudger or your fingernail to pull up on the slot in the lower left corner and remove the back cover.
  2. Blu Studio 5.5 Camera Replacement: passo 2, imagem 1 %32 Blu Studio 5.5 Camera Replacement: passo 2, imagem 2 %32
    • Place your finger in the small groove beneath the battery.
    • Push the battery toward the top of the phone and lift it out.
  3. Blu Studio 5.5 Camera Replacement, Camera: passo 3, imagem 1 %32
    • Begin by removing the 12 3.5mm screws along the back of the device.
    • 1 of these screws will be underneath a white sticker. Just press the screwdriver through it and remove it normally.
  4. Blu Studio 5.5 Camera Replacement: passo 4, imagem 1 %32 Blu Studio 5.5 Camera Replacement: passo 4, imagem 2 %32
    • Using your plastic opening tool, begin carefully prying the plastic shell from the phone.
    • Make your way around the edge slowly and lift the shell off when you have made a full circuit.
  5. Blu Studio 5.5 Camera Replacement: passo 5, imagem 1 %32
    • Locate and unplug seven connectors on the motherboard.
    • Those marked in red are pulled straight up, away from the phone.
    • The connector marked in orange is pulled out horizontally.
  6. Blu Studio 5.5 Camera Replacement: passo 6, imagem 1 %32
    • Unscrew the three 3.5mm screws securing the motherboard in place.
  7. Blu Studio 5.5 Camera Replacement: passo 7, imagem 1 %32
    • Using the plastic opening tool, you can now lift the motherboard straight up and out.
  8. Blu Studio 5.5 Camera Replacement: passo 8, imagem 1 %32
    • Carefully wedge the plastic remover tool underneath the corner of the camera module and slowly pry until it comes free.
  9. Blu Studio 5.5 Camera Replacement: passo 9, imagem 1 %32 Blu Studio 5.5 Camera Replacement: passo 9, imagem 2 %32 Blu Studio 5.5 Camera Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to lift the camera module out, taking care not to get any fingerprints on it.
    • During reassembly, make sure the ribbon attached to the camera goes up and through the square hole on the motherboard so it is able to reconnect properly.
Conclusão
3 outras pessoas executaram este guia.
Brian Sullivan
Membro desde: 10/22/14
647 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-2, Shastany Fall 2014 Membro de UMass Dartmouth, Team 1-2, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G2
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 1,111
