Ir para o conteúdo principal
Blu Studio 5.5 Back Panel Assembly Removal
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Blu Studio 5.5 Back Panel Assembly Removal, Battery: passo 1, imagem 1 %32 Blu Studio 5.5 Back Panel Assembly Removal, Battery: passo 1, imagem 2 %32 Blu Studio 5.5 Back Panel Assembly Removal, Battery: passo 1, imagem 3 %32
    • Locate the notch to remove the back panel at the lower left corner of the panel.
    • Insert the plastic opening tool or a fingernail into the notch.
    • Apply force upwards until back panel becomes loosened.
  2. Blu Studio 5.5 Back Panel Assembly Removal: passo 2, imagem 1 %32 Blu Studio 5.5 Back Panel Assembly Removal: passo 2, imagem 2 %32
    • Remove the loosened back panel and set aside.
    • Locate the notch to remove the battery.
  3. Blu Studio 5.5 Back Panel Assembly Removal: passo 3, imagem 1 %32 Blu Studio 5.5 Back Panel Assembly Removal: passo 3, imagem 2 %32 Blu Studio 5.5 Back Panel Assembly Removal: passo 3, imagem 3 %32
    • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
    • Remove the battery and set aside.
  4. Blu Studio 5.5 Back Panel Assembly Removal, Back Panel Assembly: passo 4, imagem 1 %32 Blu Studio 5.5 Back Panel Assembly Removal, Back Panel Assembly: passo 4, imagem 2 %32
    • Locate all twelve screws along the back panel:
    • Seven 5mm screws.
    • Five 3.5mm screws.
    • Using a Phillips #000 screwdriver, remove all twelve screws.
  5. Blu Studio 5.5 Back Panel Assembly Removal: passo 5, imagem 1 %32 Blu Studio 5.5 Back Panel Assembly Removal: passo 5, imagem 2 %32 Blu Studio 5.5 Back Panel Assembly Removal: passo 5, imagem 3 %32
    • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
    • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
    • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
    • Remove the panel as if you were turning the page of a book.
Conclusão
Equipe
USF Tampa, Team S1-G6, Nance Spring 2017 Membro de USF Tampa, Team S1-G6, Nance Spring 2017
USFT-NANCE-S17S1G6
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 60
