Ir para o conteúdo principal
Blu L120 Motherboard Replacement
O que você precisa
  1. Blu L120 Motherboard Replacement, Remove back panel: passo 1, imagem 1 %32 Blu L120 Motherboard Replacement, Remove back panel: passo 1, imagem 2 %32 Blu L120 Motherboard Replacement, Remove back panel: passo 1, imagem 3 %32
    • Remove the cover by lifting the notch towards the bottom of the phone. Use your fingernail to lift it up.
  2. Blu L120 Motherboard Replacement, Screw Removal: passo 2, imagem 1 %32 Blu L120 Motherboard Replacement, Screw Removal: passo 2, imagem 2 %32 Blu L120 Motherboard Replacement, Screw Removal: passo 2, imagem 3 %32
    • Remove these nine screws with a small phillips screwdriver. They are all the same size.
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it .
  3. Blu L120 Motherboard Replacement, Rear Panel  removal: passo 3, imagem 1 %32 Blu L120 Motherboard Replacement, Rear Panel  removal: passo 3, imagem 2 %32 Blu L120 Motherboard Replacement, Rear Panel  removal: passo 3, imagem 3 %32
    • Use the pry tool to gently separate the panel from the frame, starting from the bottom left corner and continue along the edge of the phone.
    • *WARNING* by doing this, you will void the manufacturers warranty.
  4. Blu L120 Motherboard Replacement, Separate back panel from frame: passo 4, imagem 1 %32 Blu L120 Motherboard Replacement, Separate back panel from frame: passo 4, imagem 2 %32 Blu L120 Motherboard Replacement, Separate back panel from frame: passo 4, imagem 3 %32
    • Continue using the pry tool around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Motherboard Replacement, Camera Removal: passo 5, imagem 1 %32 Blu L120 Motherboard Replacement, Camera Removal: passo 5, imagem 2 %32 Blu L120 Motherboard Replacement, Camera Removal: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the pry tool to disconnect the camera from the device.
    • Gently lift the camera up and use the tweezers to remove it from the phone.
    • Reinstall the camera. Then follow the guide in reverse to put the phone back together.
  6. Blu L120 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Blu L120 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32 Blu L120 Motherboard Replacement, Motherboard: passo 6, imagem 3 %32
    • Remove these three screws using 00 Philips screwdriver. Note the smaller screw circled in orange.
    • Then gently pry up on the metal antenna connector at the end of the grey wire. Move the wire out of the way.
  7. Blu L120 Motherboard Replacement: passo 7, imagem 1 %32 Blu L120 Motherboard Replacement: passo 7, imagem 2 %32
    • Next you must disconnect these three cables.
    • Use your pry tool to lift up on the brown tab to release the ribbon cable.
  8. Blu L120 Motherboard Replacement: passo 8, imagem 1 %32 Blu L120 Motherboard Replacement: passo 8, imagem 2 %32 Blu L120 Motherboard Replacement: passo 8, imagem 3 %32
    • For the last ribbon cable, use a spudger to gently pry up on the board under the right sim card slot.
    • Next, take your pry tool to lift up on the brown tab holding down the ribbon cable.
    • The cable is now free to be pulled back out of its' slot.
  9. Blu L120 Motherboard Replacement: passo 9, imagem 1 %32 Blu L120 Motherboard Replacement: passo 9, imagem 2 %32 Blu L120 Motherboard Replacement: passo 9, imagem 3 %32
    • Using a spudger, peel up on the mesh tape then use your tweezers to peel the rest of it up.
  10. Blu L120 Motherboard Replacement: passo 10, imagem 1 %32 Blu L120 Motherboard Replacement: passo 10, imagem 2 %32 Blu L120 Motherboard Replacement: passo 10, imagem 3 %32
    • Now that the motherboard is free to be pried up, be sure that no cables are in the way or can be snagged when removing the motherboard.
    • Just lift up and away.
    • Follow the instructions in reverse to put the phone back together.
Conclusão
Julio
Membro desde: 10/25/14
695 Reputação
Autoria de 6 guias
Equipe
Gateway, Team 1-5, Johnson Fall 2014 Membro de Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 741
