Ir para o conteúdo principal
Blu L120 MicroSD Card Replacement
O que você precisa
  1. Blu L120 MicroSD Card Replacement, Adding additional storage: passo 1, imagem 1 %32 Blu L120 MicroSD Card Replacement, Adding additional storage: passo 1, imagem 2 %32
    • Turn off the device, and remove the back cover. Start on the notch above the charging port and lift cover up and gently work around the phone until the back cover is off.
    • Remove the battery.
  2. Blu L120 MicroSD Card Replacement, Adding additional storage: passo 2, imagem 1 %32 Blu L120 MicroSD Card Replacement, Adding additional storage: passo 2, imagem 2 %32
    • Insert the media card into the phone. Maximum 32gb micro SD.
    • Reinstall the battery and back cover, and power on your device. Success............. you just added more storage to your phone.
Conclusão
Julio
Membro desde: 10/25/14
695 Reputação
Autoria de 6 guias
Equipe
Gateway, Team 1-5, Johnson Fall 2014 Membro de Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 188
