Ir para o conteúdo principal
Blu Grand M Speaker Replacement
O que você precisa
  1. Blu Grand M Speaker Replacement, Battery: passo 1, imagem 1 %32 Blu Grand M Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Speaker Replacement: passo 2, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Speaker Replacement: passo 3, imagem 1 %32 Blu Grand M Speaker Replacement: passo 3, imagem 2 %32 Blu Grand M Speaker Replacement: passo 3, imagem 3 %32
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Speaker Replacement: passo 4, imagem 1 %32 Blu Grand M Speaker Replacement: passo 4, imagem 2 %32
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Speaker Replacement, Speaker: passo 5, imagem 1 %32 Blu Grand M Speaker Replacement, Speaker: passo 5, imagem 2 %32
    • Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
    • Remove the 4.0mm screw with a Phillips #000 screwdriver.
    • Using the blue plastic opening tool, remove the exterior cover.
  6. Blu Grand M Speaker Replacement: passo 6, imagem 1 %32 Blu Grand M Speaker Replacement: passo 6, imagem 2 %32 Blu Grand M Speaker Replacement: passo 6, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove each of the four 1.5mm screws.
    • Use a Phillips #000 screwdriver to remove each of the three 3.0mm screws.
    • Use the plastic opening tool to remove the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
Cameron Retzlaff
Membro desde: 09/17/18
608 Reputação
Autoria de 5 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 120
