Ir para o conteúdo principal
Blu Grand M Display Replacement
O que você precisa
  1. Blu Grand M Display Replacement, Display: passo 1, imagem 1 %32
    • Trace the outer black edge of the phone screen in a continuous circle with a hairdryer or heat gun to melt the adhesive.
    • Melting the adhesive can take between 2-3 minutes.
  2. Blu Grand M Display Replacement: passo 2, imagem 1 %32 Blu Grand M Display Replacement: passo 2, imagem 2 %32 Blu Grand M Display Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Halberd Spudger
    $2.99
    • Insert an opening pick between the screen and the raised black plastic frame.
    • The black plastic frame is located inside and above the phone's silvery outer metal frame.
    • Insert the flat blade of a nylon halberd spudger between the screen and the black plastic frame.
    • Pull the spudger blade through the adhesive around the circumference of the screen.
  3. Blu Grand M Display Replacement: passo 3, imagem 1 %32 Blu Grand M Display Replacement: passo 3, imagem 2 %32 Blu Grand M Display Replacement: passo 3, imagem 3 %32
    • Apply the suction cup to the phone screen, pressing lightly on the suction cup to remove air and form a tight seal.
    • The adhesive may have cooled from the time since step 1 and rebonded to the phone screen. Reheat the adhesive if necessary to return to a liquid state.
    • Pull on the handle to lift the screen free from the device.
Linha de Chegada
Liam Rollins
Membro desde: 11/04/19
253 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 333
