Ir para o conteúdo principal
Blu Grand M Camera Replacement
O que você precisa
  1. Blu Grand M Camera Replacement, Battery: passo 1, imagem 1 %32 Blu Grand M Camera Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Camera Replacement: passo 2, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Camera Replacement: passo 3, imagem 1 %32 Blu Grand M Camera Replacement: passo 3, imagem 2 %32 Blu Grand M Camera Replacement: passo 3, imagem 3 %32
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Camera Replacement: passo 4, imagem 1 %32 Blu Grand M Camera Replacement: passo 4, imagem 2 %32
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Camera Replacement, Plastic Plate: passo 5, imagem 1 %32 Blu Grand M Camera Replacement, Plastic Plate: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the yellow plastic tape using a pair of tweezers.
  6. Blu Grand M Camera Replacement: passo 6, imagem 1 %32 Blu Grand M Camera Replacement: passo 6, imagem 2 %32 Blu Grand M Camera Replacement: passo 6, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove two black 4.0mm screws.
    • Use a Phillips #000 screwdriver to remove 2 silver 4.0mm screws
    • Remove the plastic cover along the top by tugging on it on the corner as shown.
  7. Blu Grand M Camera Replacement, Camera: passo 7, imagem 1 %32 Blu Grand M Camera Replacement, Camera: passo 7, imagem 2 %32
    • Use the plastic opening tool to lift the camera out.
Conclusão
Kristen Gismondi
Membro desde: 11/12/14
92.574 Reputação
Autoria de 241 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.632 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 154
