Ir para o conteúdo principal
Blu Grand M Battery Replacement
O que você precisa
  1. Blu Grand M Battery Replacement, Battery: passo 1, imagem 1 %32 Blu Grand M Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Battery Replacement: passo 2, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Battery Replacement: passo 3, imagem 1 %32 Blu Grand M Battery Replacement: passo 3, imagem 2 %32 Blu Grand M Battery Replacement: passo 3, imagem 3 %32
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Battery Replacement: passo 4, imagem 1 %32 Blu Grand M Battery Replacement: passo 4, imagem 2 %32
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Cameron Retzlaff
Membro desde: 09/17/18
608 Reputação
Autoria de 5 guias
Equipe
Um comentário
i need to buy a replacement battery for this phone but i don’t know which one to get. please help
S_meals 562 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 2,434
