Ir para o conteúdo principal
Blu Dash 5.0 Dual SIM Speaker Replacement
O que você precisa
  1. Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: passo 1, imagem 1 %32 Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Make sure device is disconnected and turned off.
    • Locate the groove at the bottom left corner of the phone.
    • Insert the plastic opening tool in the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 2, imagem 1 %32
    • Pry the battery out from the back of the phone using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 3, imagem 1 %32
    • Remove the 12 screws located at the back panel of the phone using a J000 screwdriver.
    • The red circles are screw holes that hold the 3.5mm length Phillips screw.
    • The orange circles are screw holes that hold the 2.5mm length Phillips screw.
  4. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 4, imagem 1 %32 Blu Dash 5.0 Dual SIM Speaker Replacement: passo 4, imagem 2 %32 Blu Dash 5.0 Dual SIM Speaker Replacement: passo 4, imagem 3 %32
    • Remove the back panel of the phone with your hand.
    • Carefully remove the plastic back panel to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 5, imagem 1 %32
    • Remove the antenna cable connectors using a spudger.
  6. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 6, imagem 1 %32
    • Unscrew the 2.5mm screws from the circuit board holding the speaker at the bottom of the phone.
  7. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 7, imagem 1 %32 Blu Dash 5.0 Dual SIM Speaker Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Flip the ZIF flap up with tweezers.
    • Remove the ribbon cable with tweezers.
    • The ribbon cable is sensitive and needs to be removed carefully to insure its integrity.
  8. Blu Dash 5.0 Dual SIM Speaker Replacement: passo 8, imagem 1 %32 Blu Dash 5.0 Dual SIM Speaker Replacement: passo 8, imagem 2 %32
    • Remove the speaker panel with the plastic opening tool.
    • The panel is glued onto the device and will require extra force to remove.
Conclusão
Mukish Kumar Munyady
Membro desde: 01/30/17
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-1, Baechle Spring 2017 Membro de IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 286
